TV piggy bank design project
1 Design Description
This project is based on laser cutting technology DIY Assemble the piggy bank and imitate the overall shapebilibiliThe television set incorporates personified cartoon elements.
  • Structural characteristics: Adopting a typical approachPlug in structureThrough precise buckle and slot design, each component can be tightly interlocked without the need for a large amount of glue to firmly form (it is recommended to use a small amount for key stress points) UHU Reinforced with glue or white latex.
  • Functional layout:
    • Front panel: Design a "screen" area that includes personified expressions (squinting eyes)/Cool expression + The mustache adds fun. There is a coin slot at the top (reserved through a card slot structure).
    • side/base The elongated side panel is designed with a textured area (indicated by the red vertical line in the picture), which serves both as decoration and may be used to increase friction or obscure internal structures.
    • back/internal There is a cash withdrawal port or bottom cover structure (with a buckle design below the right panel) for easy coin retrieval.
    • Decorative floor mats: The bottom is equipped with circular "feet" or wheels (circular components with characters in the picture), which make the TV look more vivid and also serve as support.
II Source of inspiration
  • Inspiration comes frombilibiliThat is a part of many people's childhood memories. Combining the traditional habit of saving money with“bilibili”Combining means "accumulating wealth and reviewing classics".
  • pixel/Cartoon style: The facial expressions adopt simple geometric shapes (trapezoidal eyes, wavy beard), similar to the pixel style or simple ones in early electronic games Emoji Emotions endow objects with vitality, making them not just containers, but also desktop ornaments.
  • Modular design: Drawing inspiration from modern laser cutting DIY The design language of kits (such as wooden puzzles) emphasizes flat packaging and the fun of hands-on assembly.
III Bill of Materials
Based on the cutting parameters in the figure (high power, low speed), it is speculated that the main material is 2mm Thick sheet metal.
Material NameSpecifications/thicknessestimated usageremark
wooden laminate (Basswood)2mm thickabout 1 ZhangPreferred material, with a burnt edge and suitable for coloring
sandpaper400eyea small amountUsed for polishing burrs after cutting
glueUHUglue/white latex adhesivea small amountUsed to reinforce the buckle connection
coinseveral-The contents of a piggy bank
4 process parameters
According to the "Layer Parameters" panel in the bottom right corner of the screenshot, the following are recommended laser processing settings. Note: The following parameters are based on common ones 40W-60W CO2 Laser cutting machine. If you are using machines of different powers, please adjust them proportionally.
1. Cutting layer - Used for external contours and internal hollowing out
Corresponding to the layer in the image 01 (black) and 02 (Red filled area) The contour cutting.
  • Processing mode: cutting
  • Speed: 13.0 mm/s
  • power : 99.0 % (Or maximum output power)
  • Instructions: This parameter is used for complete penetration 2mm board. Slow speed to ensure penetration and high power. If the black diagonal lines filling the eyes and beard in the figure represent this parameter, it indicateshollow-outhandle.
2. carve/Texture layer  - Used for surface decoration
Corresponding to the red vertical line area on the side panel in the figure, as well as possible surface text.
  • Processing mode: scan/carve —— Note: Although shown as "cutting" in the figure, the parameters 200/30 Clearly a carving parameter
  • Speed: 200.0 mm/s
  • power : 30.0 %
  • Instructions: High speed and low power, used to burn texture on the surface of the board without cutting through. This will make the side panel look more textured, or simulate the heat dissipation holes of a TV/Speaker grid.
3. Auxiliary cutting (optional)
Corresponding to the layer in the image 03/04(If there are subtle lines).
  • Suggested speed:20-30 mm/s, Power:80-90%(Used for cutting finer connection points).
5 Assembly Guide
  1. clear: Remove the cut board from the machine and gently sand the edges with sandpaper to remove burn marks and burrs.
  2. Distinguishing components:
    • AGroup: Front panel (with emoticons), back panel.
    • BGroup: Upper and lower side panels (long strip with red texture).
    • CGroup: left and right side panels/Connecting components (shorter parts).
    • DGroup: Round foot pad/Decorative buckle.
  3. Main body splicing:
    • Insert the front panel and back panel vertically into the side panel through the slot on the side(BGroup).
    • Ensure that the coin slot at the top is aligned.
  4. Reinforcement: Apply a small amount of glue to the buckle joint and press to fix it 1-2 minute.
  5. Install foot pads: Circular components(DInsert the group into the reserved hole at the bottom.
  6. Complete Wait for the glue to dry before depositing coins from the top coin slot.
related activities
This laser cutting design participated in the activity: Revitalize Home Furnishings, Laser Creation Fun "- Home Supplies Theme Laser Creation Competition
TV piggy bank
Drawing Cover - TV piggy bank
CO2 RF tube
50w
0:24:59
process parameters
cutting wooden laminate 2mm Horizontal unidirectional 99 13 1
cutting wooden laminate 2mm Horizontal unidirectional 30 200 1
cutting
component
splice
reinforce
Install foot pads
complete
Related Recommendations
5 Creation Coin
comment (6)
neterabundant
Invalid
2026-9-16 19:54
whitekingAwesome
wohaoxiangwandiannao:v:
2026-9-17 15:00
--1
--1
111211111111111111111111
2026-11-4 10:27
n2talfj3
edy7kitpoikDark【-o0-\‘【
2026-11-8 09:13
ig9kbehz
123456
2026-11-8 09:47
88_v57jv
4 days ago
TV piggy bank
drawing ID: SUCAI-1407 2026-6-15 16:38
0Contribution points
label
Update time 2026-6-15 16:38
