Design concept:
The rocket is precisely assembled from multiple laser cut wooden components, each with its own function, forming a complete, sturdy, and beautiful whole. It reflects the essence of aerospace engineering - it is the crystallization of tens of thousands of precision parts and the wisdom of countless aerospace workers, a great victory of high collaboration and systems engineering. The astronaut at the top of the rocket represents that no matter how technology leaps, the center of space will always be human, which is humanity's curiosity for the unknown, desire for exploration, and longing for the future.
This work combines the highly representative aerospace elements of rockets and astronauts through laser cutting of wooden boards and manual assembly, paying tribute to the great journey of human space exploration and expressing an eternal longing for exploring the unknown universe.
Source of inspiration
In recent years, the rapid development of China's aerospace industry has deeply inspired us, from the exploration of the moon by Chang'e to the exploration of fire by Tianwen, from the comprehensive construction of the Tiangong space station to the successful launch of the Long March series of carrier rockets. I hope that through this work, this surging passion can be transformed into concrete artistic forms, attracting more attention and support for China's aerospace industry.
Aerospace engineering is an extremely precise science, where even a tiny difference can lead to a thousand miles of error. Laser cutting is a modern technology that uses "light" as a knife and pursues ultimate precision. Using this precise technology to shape rockets that represent the pinnacle of human precision engineering is a dual tribute in both form and content.
Special note: When uploading your work, please make sure to select the correct work category. The selected work category for this competition is' Aerospace Theme Competition '.
| Draw lines | 3mmBasswood board | Horizontal unidirectional | 6 | 300 | 1 |
| cutting | 3mmBasswood board | Horizontal unidirectional | 80 | 48 | 1 |
3mmBasswood board
Processing equipment:Thunder Bolt Pro,30W
1Use drawing tools to draw the components of the rocket. To prevent the components from falling off, you can set water outlets on the graphics.
2、 After setting up a single graphic, for the same component, the array tool can be used to batch generate multiple identical graphics..
3、 In order to distinguish the assembly order of different components during assembly, text can be added to differentiate the order of the components.
(1)Select the default red line drawing layer for astronauts' spacesuits and the default black cutting layer for rocket components. Adjust the layer order in the lower right corner and sort them by "line drawing, cutting" in sequence.
(2)Double click with the left mouse button to select the red tracing layer and choose the oak board,3mmDraw lines and set processing parameters: speed is300The power is6Weakly blowing.
(3)Double click the black layer that needs to be cut with the left mouse button, select the oak board,3mmCutting, setting processing parameters: speed is50The power is80Strong blowing.
2Processing of drawings
1After setting the processing parameters, the file can be sent to the equipment for processing. Before formal processing, a simulation preview of the processing file can be conducted first.
2、 Once you have confirmed that there are no issues with the drawings, you can click [Send] to proceed with the drawing processing. During processing, it is recommended to use tools such as strong magnets to flatten and fix the wooden board, as unevenness may affect the processing effect.
Disassemble the processed rocket components, assemble them separately according to the assembly sequence, and finally install the top astronaut, completing the work.
Here are more reference cases about "aerospace" laser creations. Welcome everyone to unleash unlimited creativity together!
One part is missing from the drawing
The link has expired.
Is it impossible to download?
exquisite
Beautiful, exquisite!
After downloading, opening it is empty
4566
