Dry battery storage box design project
1、 Dry battery storage box Design philosophy
Design concept: This dry battery storage box is an original laser cut wooden maker work from Hengxing Middle School Science and Technology Innovation Center, designed for primary and secondary school science and technology innovation laboratories, general technology classrooms, and science club scenes.
1. Prioritize safety and solve laboratory pain points. Scattered stacking in the laboratory 5 Number7 Dry batteries are prone to potential hazards such as short circuits between positive and negative electrodes, mixing of old and new batteries, and mutual contamination of battery leakage. The independent circular hole grid design accommodates one dry battery in a single hole, isolates the electrodes, and physically eliminates the risk of battery short circuits, ensuring the safety of laboratory electricity use.
2. Maker education attributes, the integration of craft teaching adopts a basswood plywood mortise and tenon joint structure as a whole, which can be assembled without glue and is suitable for laser cutting processing technology. It is not only a practical storage tool, but also a practical training carrier for students to learn two-dimensional plane splitting, mortise and tenon structure, laser processing, and board modeling, achieving Creation is teaching.
3. Regularly partitioned, suitable for teaching management internal modular circular hole array, can be classified and stored 5 Number7 Number dry batteries, convenient for teachers to distinguish between new and used batteries. Flip cover dust-proof structure to prevent dust and moisture from corroding the battery and extend its storage life; The box cover supports laser engraving identification to achieve standardized management of laboratory equipment.
4. The simple and sustainable design uses environmentally friendly multi-layer oak wood panels, which are lightweight and easy to clean; The structure has no excess accessories and can be disassembled, modified, or expanded with holes; The wooden appearance is warm and natural, suitable for the atmosphere of science and technology innovation classrooms and science laboratories.
2、 Dry battery storage box Product Manual
Production unit: Hengxing Middle School Science and Technology Innovation Center
1. Product Introduction This product is a laser cut wooden mortise and tenon assembly storage box, designed specifically for primary and secondary school science and technology innovation laboratories and science classrooms, used for classified storage 5 Number7 Cylindrical dry battery. Separate holes are stored in separate compartments to effectively prevent battery short circuits, maintain dust-proof cleanliness, and facilitate unified management of experimental equipment; At the same time, it can be used as a practical training product for maker laser creation courses.
 2. Material and specifications • Material:3mm Limewood plywood • Structure: mortise and tenon buckle assembly structure, flip cover dustproof design • Functional hole position: circular hole array, suitable for conventional use 5 Number7 Dry battery • Processing method: laser cutting, surface laser engraving of text identification
3. Instructions for use
(1). Assembly: Assemble the bottom plate, side plate, partition, and cover plate according to the corresponding mortise and tenon positions, clamp them tightly to form, without the need for adhesive;
(2). Storage of batteries: Place the dry batteries vertically into the circular holes of the partition, one by one. It is recommended to place them facing the same direction for easy access; Can be partitioned to store new batteries and experimental waste batteries;
(3). Storage protection: Close the flip cover after use to prevent dust and moisture;
(4). Dismantling and storage: When it is necessary to move or store empty boxes, the boards can be split in reverse to save space by storing them flat.
4. Safety precautions
(1). Only suitable for storing ordinary carbon and alkaline dry batteries. Do not place rechargeable lithium batteries or high-capacity power batteries;
(2). Do not reverse squeeze the battery. If the battery is swollen or leaking, immediately remove it and dispose of it separately. Avoid prolonged contact with the wooden board for leaking batteries;
(3). Wooden boards are flammable and should be kept away from open flames and high temperature heat sources;
(4). It is prohibited to place metal conductors in the same hole position or cross holes to contact the two poles of the battery at the same time; 5. Waste dry batteries should be collected uniformly according to the requirements of campus garbage classification and cannot be discarded at will.
5. maintenance
(1). Keep the box dry and avoid long-term exposure to humid environments to prevent the wooden boards from becoming damp and deformed;
(2). If the board surface is contaminated with battery leakage or stains, use a dry cloth to gently wipe and clean it;
(3). The mortise and tenon joint should be disassembled and installed lightly to avoid strong bending and breakage of the board;
(4). When not in use for a long time, empty the battery and store it flat.
6. Expansion Explanation This storage box is designed with an open-source maker structure. In the science and technology innovation classroom, the number and size of circular holes can be modified using design software according to needs, and it can be adapted to other specifications of cylindrical batteries. It also supports personalized carving of class and laboratory names.
Drawing Cover - Dry battery storage box
CO2 RF tube
0:17:29
process parameters
Design sketches, perform carving and cutting
drawing ID: SUCAI-1514 2026-7-15 20:45
10Contribution points
Update time 2026-7-15 20:45
