Carved connecting rod storage box design project
This work is a wooden carved storage box, long25cm, Wide18cm, high18cmBy utilizing a connecting rod mechanical structure, the effect of multi-layer synchronous opening of the lid can be achieved.
The side of the box adopts a parallel four-bar linkage structure as the core transmission structure, without the need for additional parts such as gears and springs, relying on the linkage to achieve motion transmission. When opening the box cover, the connecting rod pulls the storage drawers of each layer to synchronously expand outward in a stepped manner, and the drawer bodies of each layer always maintain a horizontal posture; Close the box cover, and the multi-layered storage compartments will be synchronously retracted into the interior of the box.
The surface of the box is carved with retro European decorations, and the patterns are arranged according to the outline of the box. The box is assembled using mortise and tenon joints, and can be assembled as a whole without the need for glue.
Fixed version of connecting rod storage box
Drawing Cover - Fixed version of connecting rod storage box
CO2 RF tube
0:49:15
process parameters
cutting - - - - 1
Division packaging body
Assemble the connecting rod, pay attention to the direction of the connecting rod
Related Recommendations
5 Contribution points
drawing ID: SUCAI-1567 2026-8-11 10:15
30Contribution points
label
Update time 2026-8-11 10:15
