1、 Design concept This work is based on The ancient charm is reborn, and light and shadow create fun As the core, we combine the aesthetics of traditional Chinese window frames with modern laser technology to create a home night light that combines Eastern charm and practical value. The overall structure adopts a cubic mortise and tenon structure, with classic floral window patterns replicated on six sides. When warm light passes through the hollow wooden grid, it can project rich layers of light and shadow in the space, retaining the classical architecture Step by step and change scenery The poetry is infused with a warm atmosphere in the corners of the home through modern creative methods, achieving a seamless connection between traditional aesthetics and contemporary home life.
2、 Inspiration source The inspiration comes from the window grilles and flower patterns in traditional Chinese architecture. These patterns are not only decorative details of the building, but also unique expressions of order, symmetry, and artistic conception by ancient people. In the fast-paced modern life, we hope to use laser engraving technology to condense this classical elegance into a square wooden box, making a small night light a bridge connecting traditional aesthetics with daily home decor. We use light and shadow to tell the story of Eastern aesthetics, and also to Revitalizing Home Furnishings, Creating Fun with Laser Technology The theme endows an expression that combines cultural warmth and craftsmanship ingenuity. 3、 Basic parameters Laser type: CO2 RF tube Laser power:30W Processing time: approximately 30 Minutes (including carving and cutting) Processing equipment:Wainlux X1-10Wlaser cutting machine 4、 Process parameters I am usingcutlabXsoftware andWainlux X1-10WLaser cutting machine, specific parameters are as follows
Processing Technology processed material pattern power (%) speed (mm/s) processing times Surface carving 2.8mm Basswood board Horizontal unidirectional 75 3500 1 Contour cutting 2.8mm Basswood board Horizontal unidirectional 85 250 1 5、 Material List 2.8mm Limestone boardLED Warm light panel, battery pack, charging module, touch switch 6、 Design and production process (1) Drawing Design adopt LaserMaker V2.1.7.2 Software drawing drawings, extracting classic geometric patterns of Chinese window frames, designing six sided symmetrical hollow patterns, and adding decorative curled grass patterns at the corners to echo traditional aesthetic styles; To adapt to the mortise and tenon joint structure, precise male and female card slots are designed to ensure the stability of cube assembly. At the same time, carving and cutting layers are distinguished, and different process parameters are marked; Separate the six sided pattern and mortise and tenon structure, optimize the line details, avoid narrow hollowing that may cause processing fractures, and complete the refinement of the drawing.
On the right side, there is a "brilliant idea"--decorative border Find these two patterns, select and adjust the length of the two pillars on the left and right sides of the lace
Combine and draw a framework
Add male and female card slots to the framework15mmwide ,2.8mmHigh (I have set a tolerance)0.2mm)
Select the process and add the touch switch logo on the top surface
typesetting
(2) Laser processing Parameter setting: Surface carving of oak board (speed)3500mm/sPower consumption 75%Weak blowing to ensure clear texture; Cutting the contour of oak board (speed) 250mm/sPower consumption 85%Strong blowing to ensure smooth cutting surface without burnt edges; Material fixation: fix 2.8mm Place the oak board flat on the honeycomb board of the equipment and fix it with a magnet to prevent the board from shifting during processing; Simulation preview and processing: Preview the processing range of the drawing, send the file after confirmation, and the equipment will automatically complete the carving and cutting processes. Observe the processing status throughout the process to avoid abnormal situations.
(3) Finished product assembly and debugging Dismantle all processed components, remove edge burrs, and assemble the cubic frame in sequence according to the mortise and tenon structure to ensure that the slots are tightly fitted; install LED Warm light strip and power module, fix the position of the light strip to ensure that the light evenly passes through the hollow pattern; Power on and debug the lighting effect, check the light and shadow projection effect, fine tune the position of the light strip, and finally complete the assembly of the finished product.
7、 Work positioning This work is classified as a home furnishings theme, focusing on the need to create a home atmosphere. It uses laser engraving technology to empower traditional Chinese aesthetics and create a night light product that combines decoration and practicality. It is not only a lighting fixture that illuminates the space, but also a home decoration that carries Eastern aesthetics. It is suitable for various scenes such as bedrooms, study rooms, and entrances, injecting unique cultural texture and warm atmosphere into the home with light and shadow, perfectly interpreting it Revitalizing Home Furnishings, Creating Fun with Laser Technology The theme of the event.
@author I putTAThe pattern on the outer shell of the lamp has been modified. Can you send it out?
fraud
