Wuma Besturn Bookmark design project
This is a laser engraved bookmark specially designed for the Year of the Horse. with Five galloping horses Carving patterns for the core, combined with Success on horseback, leading the way The auspicious symbolism of the hollowed out steed is agile and lifelike, paired with elegant golden tassels. It is not only a beautiful companion during reading, but also a New Year cultural and creative activity to convey blessings.
Year of the Horse bookmark
Drawing Cover - Year of the Horse bookmark
CO2 RF tube
0:28:19
process parameters
Shallow carving 3mmBasswood board Horizontal unidirectional 50 998 1
cutting 3mmBasswood board Horizontal unidirectional 75 11 1
Bill of Materials
3mmBasswood board
Tassel accessories
Processing equipment:Thunder Bolt Pro ,30W
design process
1Click on the rectangle tool and draw a long rectangle150mm, wide45mmThe rectangle
2Select the fillet tool with a radius of5mmSet the four corners as rounded corners
3Open itLaserMakerSoftware, click on the file, import the image
4Click on the contour extraction function in the upper right corner of the image to extract the contour of the image. After extracting the contour, delete the original image
5After successful contour extraction, check the extracted graphics, delete some unnecessary things, check the contours, and use eraser tools and line segment tools to optimize the graphics
6Click on the outline of all horses' shapes, select the offset curve, and offset outward
7Select the outer contours of all horses and click on the merge tool
8Frame the entire graphic and add a layer for shallow carving technique
9Click on the outline of the graphic and add a layer as the cutting process
10Select the rectangle tool, draw another rectangle, adjust the appropriate size to connect with the pattern.
11Click on the shape of the horse and select the difference tool
12Click on the text tool to add text
13Set the processing parameters for the layer
14Click on the array tool to generate multiple identical graphics in batches
processing
1After the device is successfully connected, send the drawing to the device
2Add processing materials, as the wooden board is uneven, it is necessary to use magnets to fix and flatten the processing materials
3Focus on materials
4Positioning of processed materials
5After ensuring that the settings are correct, you can start processing
finished product assembly
1After processing, remove the processed parts
2Install the tassel accessories onto it
3Finished product completed
Related Recommendations
5 Contribution points
comment (4)
capybara_23
This bookmark is good
2026-4-13 22:00
wo07h6r2
good
2026-1-23 13:30
Wang Jun_6229
Beautiful bookmark
2026-6-15 11:19
13882770092
The Five Horses Galloping bookmark has some meaning
2026-3-24 09:05
drawing ID: SUCAI-1132 2026-1-22 15:24
17
5Contribution points
label
Update time 2026-1-22 15:24
