My Little Pony-Biqi keychain design project
The appearance of Biqi in "Little Pony" features pink fur and cute eyes that exude the vitality of the Year of the Horse. Hang the bag, hang the key, and mark the Year of the Horse Good luck with cuteness Carrying it around~
Little Ma Baoli Biqi
Drawing Cover - Little Ma Baoli Biqi
CO2 RF tube
0:4:8
process parameters
cutting 1mmnon-woven fabric Horizontal unidirectional 25 300 1
Bill of Materials
Multi-color non-woven fabric
keychain
hot melt adhesive
Processing equipment:Thunder Bolt Pro ,30W
design process
1Open itLaserMakerSoftware, click on file, import image, modify image size
2Click on the contour extraction function in the upper right corner of the image to extract the contour of the image
3After extracting the contour, delete the original image, check the extracted contour, and optimize the graphic
4Add non-woven fabric material in the custom material section
5According to different colors of non-woven fabrics and design graphics, set different color processing layers for easy processing
6To facilitate hanging the keychain, a rectangle needs to be added and made into a hook
processing
1After the device is successfully connected, send drawings to the device according to different layers
2According to different layers, place non-woven fabrics of different colors separately
3Focus on materials
4Positioning of processed materials
5After ensuring that the settings are correct, you can start processing
finished product assembly
1After processing, remove the processed parts
2Using hot melt adhesive to bond various parts together
3Finally, install the keychain and complete the finished product
Related Recommendations
5 Contribution points
10 Contribution points
drawing ID: SUCAI-1115 2026-1-13 17:46
0Contribution points
  • classification
  • copyright
  • Business License
    Further information
label
Update time 2026-1-13 17:46
