Elderly image non-woven keychain design project
Design concept:Double Ninth Festival, also known as Climbing Festival or Senior Citizens' Day, is a traditional Chinese folk festival that falls on the ninth day of the ninth lunar month every year. Inherited to this day, it has also added connotations such as respecting the elderly. Create this Double Ninth Festival elderly pendant to understand the significance of the festival and feel its festive atmosphere, while expressing the spirit of respecting and loving the elderly.
Creative inspiration:On the Double Ninth Festival, there is a custom of enjoying a banquet to pray for longevity, expressing people's blessings for the health and longevity of the elderly. Directly using the image of an elderly person can better express the connotation of the Double Ninth Festival in a simple and clear way.
Drawing Cover - Elderly image non-woven keychain
0:7:48
Create a list
1Style design: beard, tie, button, head, hair, body, collar, smiling face, white eyes, eyeballs, keychain connection
2、   Material Decoration: Non woven fabric (white, yellow skin tone, bright red, dark green, lake blue, navy blue, black), hot melt adhesive, keychain accessories
3Processing equipment: Blu ray equipment
design process
1、   Search for 'Beard' and 'Tie' simple strokes online, and choose your favorite picture to save.
2、   How to draw a perfect circle of the head, eyes, eyeballs, hair, etc? openLaserMakerSoftware, click on the oval tool on the left, hold downCtrlPress the key to draw a perfect circle.
3How to draw a semi-circular smiling face? openLaserMakerSoftware, click on the tool in the left rectangle, hold downCtrlDraw a square with the key. Click on the elliptical tool on the left again and hold it downCtrlKey, draw a perfect circle on the basis of the square just drawn. After drawing, select the square and click on the difference tool on the left to obtain a smiling face.
4、   How to draw multiple identical body shapes? Select the shape and choose the array tool on the left to generate multiple identical shapes according to your needs.
5How to draw beard and tie? Import the selected image, extract the contour, delete the original image, and modify and improve the extracted contour according to your desired effect.
Laser processing
1Set processing layers and parameters
According to your own design effect, set the processing layers separately, and use different colors of non-woven fabric to separate different processing layers.
Bottom layer of body, hair, beard, white eyes, and keychain connection: Select the above graphics, click on the bottom left corner with the mouse to add a new layer, and after creating the new layer, Double click the layer, select the process as [Cutting], double-click [Cutting], and set the cutting parameters. The cutting speed is5The cutting power is99The corner power is10Processed with white non-woven fabric.
The processing parameter settings for other layers are as follows:
2Processing of drawings
After designing the processing parameters, the equipment can be connected for processing. According to the processing layer, process separately (when processing a certain layer, other layers can be hidden)
Attention: When changing the processing layer, the corresponding non-woven fabric color should be changed synchronously
finished product assembly
1、   Adhere the processed materials with hot melt adhesive according to the design drawings and assemble them in sequence.
2After assembly, add keychain accessories to complete the work.
Work video
drawing ID: SUCAI-639 2024-10-10 11:11
10Contribution points
Update time 2024-10-10 11:11
