Laser Creation Beginner Course | Case 11: Car shaking ornament design project
Car decorations are a form of culture that conveys blessings and expectations, reflecting the personality and aesthetics of car owners. Car mounted shaking ornaments, as one type, have a unique dynamic beauty that allows car owners to experience a visual sensation of movement while driving, making it easier for them to concentrate. In this issue, Laser Expert brings you the work "Car Moving Head Pendant"!
Pikachu car shaking ornament
Drawing Cover - Pikachu car shaking ornament
0:11:56
Appearance production
(1)Enter the keyword "Pikachu Sketches" in Baidu and select your favorite image to save; Click on 'File' in the 'Function Area' above, and then click on 'Print'
Open, double-click to open the saved Pikachu image, as shown in the following figure:
(2) Click the left mouse button on the image and select 'Extract Contour',Obtain a rough line diagram of Pikachu, as shown in the following figure:
(3)Remove excess lines and background, add some strokes appropriately, and separate Pikachu's head and body into two parts to obtain the Pikachu line diagram, as shown in the following figure:
(4) Select the outer contour lines of Pikachu's head and body, respectively,ctrl+cCopy, thenctrl+vPaste to obtain the outline lines of Pikachu. And move it to the original location
The outer contour of Pikachu overlaps, as shown in the following figure:
Laser processing
(1)Select 'Pikachu's Head and Body', left click on the layer panel in the lower left corner to change the layer to yellow, as shown in the following figure:
(2)Select the "outer contour line" and move it to coincide with the original Pikachu, as shown in the following figure:
(3)Double click the yellow layer with the left mouse button to set the material, thickness, and process to acrylic3mmShallow carving; Double click the black layer with the left mouse button to separate the material, thickness, and process
Don't set it to acrylic3mmCut, as shown in the following figure:
Works Display
Summary:
  In the production process of this instance, we need to color Pikachu, but acrylic is difficult to color and can easily make the entire pattern look dirty. To overcome this difficulty,
Just need to be careful and patient, carefully craft during the coloring process, take it slow, and you can get a satisfactory coloring work! Drawing and modeling are not difficult, everyone must try more,
Practice more to become a better little designer!
drawing ID: SUCAI-19 2024-4-7 14:07
0Contribution points
Update time 2024-4-7 14:07
