speech recognitionAIIntelligent running light design project
Drawing video
         The walking horse lantern is a traditional folk handicraft in China, which relies on hot air to drive the impeller to rotate, and the pattern on the lamp surface rotates in a circular manner, full of traditional light and shadow fun. However, traditional running lights can only operate passively without interactive capabilities, and their functional forms are relatively simple. This work combines traditional lantern culture with modern times AI Combining speech recognition and embedded electronic technology to create an intelligent running light that can interact with speech.
Purpose of the work: To inherit the intangible cultural heritage of traditional horse lanterns, integrate artificial intelligence, programming, and mechanical structures, and achieve modernization and innovation of traditional culture; Make ancient lanterns no longer just passive viewing, with voice control of lighting, rotation start stop, and speed, experience the fun of human-machine voice interaction, and feel the charm of the collision between tradition and technology 2、 Introduction to the functions of the work
This work is AI The intelligent running light driven by voice recognition supports offline voice recognition and does not require a network connection. All operations can be completed by saying voice commands:
1. Voice wake-up control: Voice commands are issued to start and stop the rotation of the running light.
2. Speed voice adjustment: Voice controls the speed to increase or decrease, allowing for free adjustment of the lantern's rotation speed.
3. Light voice control: Voice control the color lights to turn on and off, adjust the brightness and color mode of the lights.
4. Sound and light feedback: After recognizing a valid voice command, the light will flash to give a response prompt.
5. Traditional appearance effect: When the lantern shell rotates, the traditional pattern on the lamp surface flows in a loop, restoring the traditional light and shadow effect of the running horse lantern.
speech recognitionAIIntelligent running light laser cutting drawing
Drawing Cover - speech recognitionAIIntelligent running light laser cutting drawing
CO2 RF tube
80
Voice recognition sensor, light strip ,arduino uno main control board
3:44:11
process parameters
cutting 3mm Lime board Horizontal unidirectional 70 25 1
The production steps are as follows
Just follow the steps.
drawing ID: SUCAI-1643 2026-10-12 22:27
5Creation Coin
label
Update time 2026-10-12 22:27
