Intelligent maintenance bed design drawings
Title: Intelligent Maintenance Bed Model
Synopsis
This work adopts3mm Basswood board, through LaserMaker Complete structural modeling, laser cutting processing, and assemble to create a physical model of an intelligent maintenance bed. The work is designed for elderly people living at home, and is a multifunctional intelligent nursing prototype that integrates environmental monitoring, physiological monitoring, voice control, and bed posture adjustment. It can simulate the basic auxiliary functions of intelligent maintenance beds.
Structural Design Description
The overall shell, bed frame, bedside table, and side equipment compartment are all used 3mm The oak board is laser cut and assembled through mortise and tenon joints, without the need for complex connectors, making it easy to disassemble and assemble. The contours of the bed and cabinet are cut into layers, and the bottom plate is laser engraved with the name of the work. The appearance is simple and clean, and the structure is stable. Reserved electronic component installation slots can be used to embed hardware such as the main control board, sensors, servos, fans, display screens, etc., balancing aesthetic appearance and layout space for internal circuits.
Feature Introduction
  1. Dual monitoring of environment and physiology: equipped with DHT11 Temperature and humidity sensors, heart rate sensors, real-time collection of environmental temperature and humidity, and human heart rate data,OLED Real time display of monitoring data on the screen, stable data reading.
  2. Voice intelligent interaction: based on CI-03T Voice recognition module, voice command control LED Light strip and cooling fan start stop, easy to operate, suitable for elderly people.
  3. Bed posture adjustment: driven by servo motor, the bed board is uniformly and smoothly completed Get up / Lie down Attitude switching, simulated nursing bed assisted standing function, smooth and seamless movements without any lag.
  4. Low power design: device standby power consumption ≤5WLow work energy consumption, energy-saving and environmentally friendly.
Use hardware inventory
Arduino Uno Main control boardCI-03T Voice moduleDHT11 Temperature and humidity sensors, heart rate sensorsOLED Display screenLED Light strip, small cooling fan90° Servo and power module.
Design Insights
With the help of LaserMaker Complete the blueprint design and laser cutting of the entire basswood structure, combine the mechanical structure with open-source hardware, and use models to realize the creative idea of intelligent care. I hope to use simple and low-cost solutions to design intelligent devices that can assist the elderly in their daily lives, and experience the help that technology brings to elderly care.
Drawing Cover - Intelligent maintenance bed
0:26:14
drawing ID: SUCAI-1636 2026-9-28 10:16
10Contribution points
label
Update time 2026-9-28 10:16
