This is aYear of the Horse themed circular lantern wooden boardThe overall laser cutting solution isDouble layered outer ring circular frame + Central Jumping Cartoon Horse + Xiangyun and Flower DecorationThe hollow structure of, suitable for Yuanxiao (Filled round balls made of glutinous rice-flour for Lantern Festival)/New Year atmosphere decoration.
The highlight is the addition of a gear/The minimalist outer contour of the "gear pony" with a rotating structure is used to decorate or link small ornaments on small gears.
Applicable scenarios
Lantern Festival/Spring Festival desktop decorations, window displays, lobby decorations, and handmade gifts
structural characteristics
Circular composition, double layered outer border enhances strength and layering
The central cartoon horse has a lively design, surrounded by auspicious clouds/Flowers fill the space but remain hollow and can be cut
Extra production of 'Gear Pony': minimalist outer contour, suitable for small-sized cutting and installation
Material suggestions
plank3mmBasswood board
Lighting: Small LED string lights/Electronic candle light
| cutting | 3mmBasswood board | - | 85 | 20 | 1 |
| Shallow carving | 3mmBasswood board | Horizontal bidirectional | 40 | 1000 | 1 |
I have provided a template for the 'Year of the Horse Lantern' (structured and reusable). Everyone just needs to replace on the template/Modify the middle pattern or partial decoration.
Generate a circular lantern line draft with the theme of the Year of the Horse using prompt words (black and white, high contrast, no gradient, suitable for cutting).
When a pony needs to be decorated with gears, use the prompt "only preserve the outer contour" to generate a minimalist pony silhouette.
These are the two prompt words I used:
Laser cutting plan of circular lanterns with the theme of the Year of the Horse,SVGVector style, pure black and white line draft, circular composition, double layered circular frame in the outer circle, a cartoon jumping horse in the middle, with flowing mane, lively and lovely expression, surrounding auspicious clouds and flower decorative elements, hollow structure design, all lines are closed clearly, structure connection is reasonable, suitable for laser engraving and cutting, black solid line graphics, white background, high contrast, no shadow, no gradient, no gray scale, no perspective, graphic design, Paper Cuttings style, clean outline, high-definition details "
On the basis of maintaining the overall proportion of the original image, extract the external contour lines, only retain the outermost edge lines, delete all internal details and decorative elements, remove eyes, mane textures, muscle lines, shadows, and fillers, only retain a single continuous closed external contour path, with uniform line thickness, black strokes, and white background,SVGVector style, minimalist design, suitable for laser cutting andCNCCarving, all lines must be closed without breaks
Import generated images LaserMaker
Use the "contour tracing" function to convert the line draft into a cuttable path
Key inspection: whether the lines are closed and whether there are any excess broken points/repetition line
Put the vector pattern into the template I provide, adjust the processing technology, and see my video operation for details
If necessary, adjust the size, position, and connection bridge position to ensure a more sturdy structure
Infringement has invaded my head. They directly copied my work and replaced the patterns in it. It's really grandiose. It's quite convenient not to change the patterns, isn't it
