Colorful horse head design project
Taking the Year of the Horse as the creative core, combining the high-precision characteristics of laser processing with traditional zodiac culture. Realize precise nesting of multi-layer boards through laser cutting technology, with sharp and distinct contour lines; The color filling part draws inspiration from the collage art style, symbolizing the rich and colorful life of the Year of the Horse.
Colorful horse head
Drawing Cover - Colorful horse head
CO2 RF tube
0:8:35
process parameters
Draw lines 3mmBasswood board Horizontal unidirectional 9 200 1
cutting 3mmBasswood board Horizontal unidirectional 75 12 1
Bill of Materials
3mmLimeboard board, glue, marker pen
Processing equipment:Thunder Bolt Pro ,30W
design process
1Open itLaserMakerSoftware, click on the file, import the image
2Click on the contour extraction function in the upper right corner of the image to extract the contour of the image
3Design graphics according to your own ideas, copy graphics with different processing parameters separately, and set parameters separately.
4Set processing parameters
processing
1After the device is successfully connected, send the drawing to the device
2Insert the processing material and fix it with a fixed insert
3Focus on materials
4Positioning of processed materials
5After ensuring that the settings are correct, you can start processing
finished product assembly
1After processing, remove the processed parts
2Use glue to stick the various parts together
3Coloring the artwork with a marker pen
4Work completed
Related Recommendations
Colorful horse head
drawing ID: SUCAI-1161 2026-4-14 08:57
0Contribution points
label
Update time 2026-4-14 08:57
