Seal of 'Success on the Move' design project
Using modern laser engraving as a knife, carving galloping horses, auspicious clouds, and more on solid wood 'Success on horseback' Jiyu, using traditional printing techniques, spreads the vermilion color onto plain paper.
The collision of precise modern craftsmanship and antique rubbing texture not only pays tribute to traditional auspicious culture, but also conveys the New Year's expectation of leading the way and everything going smoothly.
Year of the Horse Seal
Drawing Cover - Year of the Horse Seal
Carbon dioxide glass tube
process parameters
deep carving 3mmsolid wood board Horizontal unidirectional 40 800 6
cutting 3mmsolid wood board Horizontal unidirectional 85 18 1
Bill of Materials
3mmsolid wood board
ink pad
Processing equipment:Thunder Bolt Pro ,30W
design process
1Open itLaserMakerSoftware, click on the file, import the image
2Click on the contour extraction function in the upper right corner of the image to extract the contour of the image. After extracting the contour, delete the original image
3Frame the entire graphic and add a layer for shallow carving technique
4Click on the rectangle tool to add a rectangle outside the shape
5Click on the newly drawn rectangle and add a layer as the cutting process
6Frame the entire graphic and adjust its size
7Click on the mirroring tool to mirror the graphics
8Set the processing parameters for the layer
processing
1After the device is successfully connected, send the drawing to the device
2Insert the processing material and fix it with a fixed insert
3Focus on materials
4Positioning of processed materials
5After ensuring that the settings are correct, you can start processing
finished product assembly
1After processing, remove the processed parts
2Clean the processed dust with clean water
3Print ink onto the pattern
4Cover on paper, finished product completed
Related Recommendations
20 Contribution points
drawing ID: SUCAI-1155 2026-2-9 14:44
0Contribution points
label
Update time 2026-2-9 14:44
