Helicopter laser engraving template design project
This is an object made of acrylic material, resembling a helicopter. The body is rectangular in shape, with cross shaped transparent blades at the top and a smaller blade structure at the tail. The overall design is simple, presenting a light and delicate feeling with a transparent texture.
design1
Drawing Cover - design1
semiconductor(blue light)laser
60W
0:15:31
process parameters
cutting 2.4mmThick acrylic sheet Horizontal unidirectional 80 8 1
design
Clearly define the theme of the event. Determine the type of helicopter to be produced. By searching for information on the internet and other methods, we can understand the external features, structural proportions, etc. of the target helicopter to ensure the accuracy and authenticity of the model.
material selection
By understanding the structure of the helicopter, acrylic plates were chosen as the material.
Design drawings and cut them
Design drawings for each component of the helicopter based on the thickness of the acrylic board to determine the required dimensions for the joints of each part. After completion, import the laser cutting equipment and adjust the parameters for cutting.
Assemble parts
Assemble the cut parts into a complete helicopter model.
Support drag and drop upload · most 10 Zhang · single sheet ≤ 3MB
Drag the image here or click "Select Image" to upload (supports multiple images)
drawing ID: SUCAI-842 2025-10-30 13:01
10Contribution points
Update time 2025-10-30 13:01
advertisement
