[Reference Example] Golden Snake Blessing Earrings design project
Design concept:
We ingeniously incorporated the image of a snake into the earring design, outlining the posture of a spirit snake with winding curves, perfectly blending softness and strength, symbolizing the endless vitality and intelligent agility.
Source of inspiration
In traditional Chinese culture, the snake is one of the twelve zodiac animals, symbolizing wisdom, mystery, and auspiciousness, and is a symbol of good fortune.2025Year is the Year of the Snake, and we draw inspiration from the cultural connotations of the Chinese zodiac snake. We hope to convey the beautiful symbolism of the snake to every wearer through this earring.
Special note: Please make sure to select the correct category when uploading your work. The selected category for this competition is' Accessories and Jewelry Competition '. Simultaneously participate in event theme selection【LaserMakerLaser Creation Creative Matching/Jewelry Design Competition.
Drawing Cover - Golden Snake Blessing Earrings
0:1:37
process parameters
Shallow carving 3mmmirror acrylic Horizontal unidirectional 45 800 1
cutting 3mmmirror acrylic - 80 10 1
Bill of Materials
3mmMirror acrylic, earring accessories
Processing equipment:Thunder Bolt Plus
design process
Using software drawing tools and contour tracing tools, draw the shape of a snake, add patterns on its body, and finally add a circular hole on the snake head for easy installation of earring accessories.
Laser processing
1Set processing layers and parameters
(1)Select the default light carved yellow layer for the pattern inside the snake, and the default cut black layer for the snake's appearance. Adjust the layer order in the bottom right corner and sort them by "light carved, cut" in sequence.
(2)Double click the yellow layer that needs to be lightly carved with the left mouse button, select acrylic,3mmShallow carving, set processing parameters: speed is800The power is45Horizontal unidirectional, weak blowing.
(3)Double click the black layer that needs to be cut with the left mouse button, select acrylic,3mmCutting, setting processing parameters: speed is10The power is80Strong blowing.
2Processing of drawings
After setting the processing parameters, the file can be sent to the equipment for processing. Kind reminder: To achieve the processing effect of mirror acrylic and highlight the pattern of the snake body, pay attention to carving on the coated side.
Entrepreneurship! It's just simple_4_Lei Xiaoyu_From the web version of Xiaohongshu_copy.jpg
finished product assembly
Clean the surface dust of the processed snake pattern with a tissue, install earring accessories, and complete the work.
Here are more reference cases about accessories and jewelry. Welcome everyone to unleash unlimited creativity together!
Create a video
drawing ID: SUCAI-758 2025-2-27 14:16
0Contribution points
Update time 2025-2-27 14:16
