Wooden specialty class board design project
Design concept:1Nature and warmth: Wooden materials give people a warm and rustic feeling, blending with the vitality and vigor of the campus, creating a friendly and comfortable atmosphere, allowing class members and visitors to feel the warmth of home, relieving the pressure of learning and work, and bringing teachers and students closer together.2Cultural Inheritance: Wood has been used for a long time in human history, carrying traditional cultural heritage. The use of wood for class signage symbolizes knowledge inheritance, inspires students to absorb cultural essence, cultivates cultural confidence, and also symbolizes the respect and inheritance of traditional values by the class, enhancing the cohesion and centripetal force of the class.3Personalized customization: Wooden class signs are easy to carve, draw, imprint and other processing, facilitating the integration of class characteristic elements, showcasing the unique style and spiritual connotation of the class, inspiring students' sense of belonging and collective honor, and highlighting the individuality and innovation of the class.
Inspiration source: The grassland symbolizes the unity of classmates in the class. Every blade of grass is like a member of the class. Although individual strength is small, numerous small grasses converge into a grassland, representing the close unity of classmates and jointly creating a harmonious and stable class environment. The big tree symbolizes the class teacher, tall and upright, providing shade for the grass (students) under the tree, just like the class teacher provides guidance and protection for students, supporting the entire class in difficult times. Our school is a growing technology education characteristic school. Characteristic education is called "Yingzhu Education", which essentially uses the faint light of students' inner longing for technology to ignite the patriotic cup that will forge great achievements for the country in the future, and strives to become the backbone of the country. So fireflies and starlight were also added.
related activities
This laser cutting design participated in the activity: the 6th LaserMaker Laser Creation Competition - Featured Sign Design
Drawing Cover - Wooden specialty class board
Carbon dioxide glass tube
80w
0:18:55
process parameters
Draw lines Basswood board3mm - 15 300 1
cutting Basswood board3mm - 16 20 1
Create a list
Design drawings:
1Style design: Rectangular rounded border with images of trees, grass, fireflies, starlight, etc. inside. Text design: Yingzhu Education, Grade 1.
2Material Decoration:3mmLimeboard, paint, glue.
design process
1Draw the outer frame of the first layer of class cards, design the internal pattern, enter "Yingzhu Education" in the upper left corner, draw grass below the frame, and set the areas that need to be outlined in red.
2Draw the outer frame of the second layer of the class card, design the internal pattern, draw a big tree on the right side of the frame, and set the areas that need to be outlined in red.
3Draw the outer frame of the third layer of the class card, design the internal pattern, draw a firefly and four stars on top of the frame, and set the areas that need to be outlined in red.
4Draw the outer frame of the fourth layer class board, design the internal pattern, enter the class name "Grade 1" in the appropriate position, and set the text to red.
Laser processing
1Set processing layers and parameters.
(1)Adjust the layer order in the bottom right corner and sort them by "stroke, cut" in sequence.
(2)Double click the red layer that needs to be traced with the left mouse button and select the oak board,3mm, stroke, set processing parameters: speed is300The power is15Weakly blowing.
(3)Double click the black layer to be cut with the left mouse button and select the oak board,3mmCutting, set processing parameters: speed is20The power is16Strong blowing.
2Processing of drawings.
After setting the processing parameters, the equipment can be connected for processing.
finished product assembly
1After the cutting is completed, clean the four layers of the class sign, with the corresponding colors on each layer of the picture. Finally, use glue to stick them layer by layer, and the wooden class sign is completed.1734394160319071.jpg
2Stick the class sign on the door frame of the corresponding class.
Work video
drawing ID: SUCAI-686 2024-12-17 09:16
0Contribution points
Update time 2024-12-17 09:16
