[Reference Example] National Day themed pendant design project
Design concept: National Day is a commemorative day to celebrate the founding of the People's Republic of China, symbolizing the independence and rebirth of the country. Every year on this day, a grand celebration is held nationwide to commemorate this important historical moment. National Day has profound significance for China and its people. To warmly celebrate the founding of the People's Republic of China75On the anniversary, make this National Day themed pendant to feel the strong festive atmosphere and wish the prosperity of our country.
Inspiration source: Selected materials from Tiananmen Square and the national flag, which are typical symbols of the People's Republic of China and can highlight the characteristics of the National Day theme. Pigeons are symbols of peace, friendship, unity, and sanctity, symbolizing family, country, and world peace, and expressing a beautiful vision. The blooming flowers serve as embellishments, making the entire work more full and beautiful, expressing the wish for a more prosperous motherland. Added balloon embellishments, highlighting the festive and joyful atmosphere of the festival.
Special note: Please make sure to select the correct category when uploading your work. The selected category for this competition is' Festival themed Pendant Competition '. At the same time, it is necessary to choose the theme of the 5th eventLaserMakerLaser Creation Competition Event.
National Day themed non-woven pendant
Drawing Cover - National Day themed non-woven pendant
0:20:21
Create a list
1Style Design: Red Flag, Tiananmen Square, White Dove, Flowers, Balloon, Leaves, Circular Ring, National Day Celebration Text
2Material Decoration: Non woven fabric (bright red)/Lemon yellow/yellow/light pink/pink/white/dark green/apple green/Light blue), hot melt adhesive, tassel accessories
3Processing equipment: Blu ray equipment
design process
1、   Search online for image materials that match National Day, such as simple stroke images of Tiananmen Square, White Dove, Red Flag, Flowers, Leaves, and Balloons. Choose your favorite image based on your own ideas and save it.
2、   openLaserMakerSoftware, select the concentric circle pattern on the right, hold down the left mouse button and drag it to the canvas, adjust the appropriate size (length and width)216mm)Add holes up and down (insert diameter up and down)5.5mmRound shape, convenient for hanging accessories.
3、   Import selected images, extract contours, delete original images, and modify and improve the extracted contours according to the desired effect. All image materials are processed for contour extraction according to the above steps.
Laser processing
1Set processing layers and parameters
According to your own design effect, set the processing layers separately, and use different colors of non-woven fabric to separate different processing layers. For easy differentiation, it is recommended to set the color of the layer to correspond to the color of the non-woven fabric.
Bottom Ring: Select the shape of the ring and click on the bottom left corner to add a new layer. After creating the new layer, Double click the layer, select the process as [Cutting], double-click [Cutting], and set the cutting parameters. The cutting speed is5The cutting power is99The corner power is10.
The processing parameter settings for other layers are as follows:
2Processing of drawings
  After designing the processing parameters, the equipment can be connected for processing. According to the processing layer, process separately (when processing a certain layer, other layers can be hidden)
Attention: When changing the processing layer, the corresponding non-woven fabric color should be changed synchronously
finished product assembly
1、   Adhere the processed materials with hot melt adhesive according to the design drawings and assemble them in sequence.
Attention: Pay attention to distinguishing between the front and back of the paste, and do not confuse them
2After assembly, add tassel accessories to complete the work.
Work video
drawing ID: SUCAI-637 2024-9-29 17:27
0Contribution points
Update time 2024-9-29 17:27
