Tingfeng Pavilion design project
This work is a three story octagonal double eave pavilion, made of solid wood sheets as raw materials, independently completed structural design, pattern drawing, laser cutting and assembly. The overall restoration of traditional ancient architecture features such as flying eaves, corridors, carved window frames, railings, and other classic shapes. Warm lighting is added to the reserved space inside, which can present the spatial hierarchy of the pavilion and create an ancient atmosphere.
Repeatedly adjusting the splitting structure, carving details, and splicing tolerances during the production process is an experimental work that involves edge design, trial cutting, and modification. At present, it is the initial finished product, and the lighting wiring scheme and surface coating have not been optimized and perfected, leaving room for adjustment. The work aims to replicate the elegant atmosphere of Chinese classical pavilions using modern laser technology, experience the beauty of traditional architectural structures, and appreciate the joy of handmade creation and repeated polishing.
Tingfeng Pavilion Design
Drawing Cover - Tingfeng Pavilion Design
CO2 RF tube
10W
15:17:41
process parameters
Individual details have defects, which can be repaired with file glue. I designed my own game without detailed reference pictures, but I classified the design draft and installed it from bottom to top in orderScreenShot_2026-11-24_201631_075.png
Tingfeng Pavilion
drawing ID: SUCAI-1703 2026-11-24 20:41
5Creation Coin
label
Update time 2026-11-24 20:41
