This is a small sampan with a multi-layered laminated board structure assembled by laser cutting of oak wood(Dory/Flat bottomed small boat
Handmade model kit, belonging to makers/STEMA commonly used introductory boat model teaching tool in club classes, a stacked structure small boat model, also commonly known as the "Dolly Ship"(Dory)”.
1、 Structural features (corresponding to the parts in your picture)
1. Layered hull framework:5Stacking laser cut ship side panels with different profiles to form the thickness of the ship's side walls is a typical example of laminated board stacking hull(Hull) technology, used to simulate the rib structure of a real wooden boat
2. Internal deck strip: the transverse wooden strip inside the hull is the seat plate (rowing seat)
3. Supporting accessories: two oars+The small rudder blades at the stern restore the basic kayak configuration
4. Material:2mmThick oak plywood, laser precision cutting mortise and tenon joints, splicing and assembly, glue free and does not require complex tools
2、 Purpose positioning
1. primary and secondary schools/Vocational Maker Curriculum Matching Project: Used to explain ship structure, buoyancy principle, and sheet metal processing technology.
2. Static ornament model: The finished product can be used as a water landscape scene sand table accessory
3. Modified buoyancy version: enlarged (thicker compared to the previous version), sealed and waterproofed, can be made into a small sailboat for sea trials/canoe
What a cute little boat
