Hippo brand air purifier design project
this DIY Air PurifierHippopotamus biomimetic formFor design inspiration, transform cold purification equipment into household items full of childlike fun and warmth. The hippopotamus's open mouth happens to become the air outlet of the air purifier, as if the hippopotamus is using it Take a deep breath Spit out fresh and clean air for the room; The interior of the aircraft adopts mature air purification principles and achieves efficient filtration through laser cut wooden structures. The overall design breaks the industrial feel of traditional purifiers, cleverly integrating practical functions with cute appearance, becoming a home that combines purification function and healing feeling The Air Guardian.
related activities
This laser cutting design participated in the activity: Revitalize Home Furnishings, Laser Creation Fun "- Home Supplies Theme Laser Creation Competition
air purifier
Drawing Cover - air purifier
semiconductor(blue light)laser
1:49:22
process parameters
Design Ideas
I have an idle computer fan in my hand and I want to use it to make an air purifier.13.jpg
appearance design
The common appearance of air purifiers is rectangular in shape. In order to avoid a single image and make the work full of childlike charm and warmth,AICreated a hippopotamus image and made it into a household item, with the hippopotamus mouth selected as the air outletcapture.PNG
Air filter design
For the convenience of replacing the air filter in the later stage, it is designed as a pluggable and replaceable air filter design. Use a layer of window screen cloth that can be replaced at any time.
power module
The voltage of the fan is12V, regular5The battery requires eight units, making it too bulky and inconvenient to store as a power source. I have it in my hands3.7VRechargeable lithium batteries,3section11.1VIt is barely usable and does not take up too much space, but there is no suitable battery box. Therefore, I disassembled the positive and negative stages of a button battery box and proceeded to do it myselfDIYI found a wooden battery box that was just horizontally embedded into the back of the rhinoceros.
drawing ID: SUCAI-1357 2026-6-11 11:09
30Contribution points
label
Update time 2026-6-11 11:09
