This sericulture drawing machine is designed specifically for primary school sericulture courses, upgrading traditional manual drawing to convenient electric operation, allowing students to easily experience the complete process of silk extraction.
When in use, simply fix the cocoon and activate the switch to visually observe the details of the silk slowly emerging from the cocoon, and clearly perceive the traditional technique principle of "one strand of silk pulling ten thousand strands".
It not only reduces the difficulty of manual silk drawing, but also preserves the core experience of sericulture culture, helping students understand the traditional knowledge of sericulture and silk drawing in practice, and feel the wisdom of Chinese agricultural civilization.
The required materials are as follows:
3x30x40plank
One coupling device
One DC motor speed controller
2millimeter15Centimeter model axle13Root,2Millimeter shaft sleeve52a
N20gear motor1a
2One battery box for Section 5
5Millimeter width20One centimeter long wooden stick
| - | - | - | - | 1 |
No step content available at the moment
Great, you can set contribution points or create coins.
It looks great, but I think the design is simple, achieving a simple yet practical and attractive effect. Students also find it easy to get started with
