Toilet sign design project
[font=-apple-system, BlinkMacSystemFont, "]Toilet signage refers to signs used to indicate the location and gender distinction of toilets.1[font=-apple-system, BlinkMacSystemFont, "]The design of toilet signage should be concise, clear, easy to understand, and convenient for people to quickly find[font=-apple-system, BlinkMacSystemFont, "]Location of the restroom
Toilet sign
Drawing Cover - Toilet sign
0:1:34
Prepare artwork
openLaserMakerDesign the necessary signage,
Model of laser cutting machine used:ODIN32 55w;
Lens used:ODIN32 2"lens
Vector cutting: Speed:15mm/s, Power70%Corner power:20%;
confirm parameters
Please refer to your user manual for recommended engraving for your machine/Cutting parameters can also be adjusted according to the material you are using (the parameters shown in the picture are only applicable)ODIN32Laser cutting machine). After completing the parameter modification, the file can be sent to the laser cutting machine.WeChat image_20240402143125.png
Processing graphics
Place the material inodin32Adjust the laser head to the desired carving position on the honeycomb panel, and ensure that the laser head is above the material before clicking on autofocus. (If the laser cutting machine you are not using does not have autofocus function, you can use a focusing ruler to focus.) The laser cutting machine autofocus is complete.
On the machine, open the file, click to confirm the border, and then press Start.
Toilet sign
drawing ID: SUCAI-7 2024-4-2 16:06
0Contribution points
Update time 2024-4-2 16:06
