seal design project
The seal culture in China has a long history and is one of the four traditional arts of China. Seals originated as certificates of exchange for goods in commerce, and later developed into legal documents to prove the rights and interests of those in power. They are often used in politics and become "seals". With the development of the times, the symbolic function of seals has gradually weakened, while the proof function of seals has become the main function, for example, every company or enterprise has its own official seal. Observe the shape and structure of the seal and think about how to use it[font=Calibri]LaserMakerDesign and create a unique seal for oneself. 、
seal
Drawing Cover - seal
0:2:27
Step 1
Click on the 'Rectangle Tool' in the left menu barLaserMakerDraw a picture on the interface59*34mmThe square.
Screenshot of Enterprise WeChat_17151400026265.pngClick the "Ellipse" tool to draw a diameter of4mmThe perfect circle.
Copy three identical circles, select the square, right-click to copy three identical circles, for a total of four circles.
Place the four circles at the corners of the rectangle, select each one, and click the "Difference Tool".
Select the rectangle, click on the 'Offset Curve Tool', and offset outward1mm.
Select the rectangle inside, change the color to navy blue, and set it to deep carving.
Click on "Text Input" on the left menu bar of the software to bring up the text input dialog box. Enter the text you need to engrave and set the font and size.
Screenshot of Enterprise WeChat_17151482582854.pngScreenshot of Enterprise WeChat_17151591861942.png
Select the shape and click on the 'Horizontal Mirror Tool'
Step 2
Click on the 'Rectangle Tool' in the left menu bar to draw a62*37mmThe rectangle
Click on the 'Corner Tool' and set the corner radius to3mmRound the four corners of the rectangle.
Click on the 'Rectangle Tool' to draw a rectangle in the middle of the image29.5*14.5The rectangle.
Select two rectangles and copy paste them.
Step Three
Click on the menu bar on the leftRectangulartool”,draw a30*50mmofrectangle
Click on the 'Corner Tool' and set the corner radius to7mmMake rounded corners on the top two corners of the rectangle.
Screenshot of Enterprise WeChat_17151554338735.pngScreenshot of Enterprise WeChat_17151554445223.png
Select the graphic, copy and paste two.
Step Four
Arrange all the graphics neatly
Left click on the black layer and drag it to the bottom of the layer. Double click on the red deep carving layer in the bottom right corner, and set the material, thickness, and craftsmanship to oak board5mmDeep carving, setting the material, thickness, and craftsmanship of the black cutting layer to oak board5mmCutting.Screenshot of Enterprise WeChat_17151618804353.png
seal
drawing ID: SUCAI-172 2024-5-8 17:51
0Contribution points
Update time 2024-5-8 17:51
