Solar powered voice navigation assistant model design project
Drawing video
1、 Design concept and inspiration source
Creative Points of Double Festival Culture Mid Autumn Festival and National Day meet, bringing together families and celebrating the whole country. The work takes the campus as the carrier, with road sign panels carved with campus landmarks (cafeteria, dormitory, playground), simulating the scene of students waiting for shuttle buses to return home during holidays, and Family and Country Reunion Concentrated in micro platforms; The top solar panel symbolizes the brightness of the country and the fulfillment of every year.
AI How to participate in the creation of works
1. AI Auxiliary structural design: use AI Generate a creative sketch of the curved roof of the bus stop surface from the Wensheng diagram, and then use it AI Tool optimization of laser cutting tenon and mortise structure, automatic disassembly of parts, optimization of card slots, and reduction of interference problems in oak assembly; Use of carved graphics and text (place names, logos) on the front panel AI Generate layout plan and automatically adjust text size and layout.
2. AI Hardware interaction: equipped with ASR-PRO2.0Main control implementationAI Voice interaction, after waking up, you can ask questions about Mid Autumn Festival and National Day folk knowledge, and broadcast bus arrival prompts; At the same time, it integrates an induction module, which automatically turns on the fan for air supply and plays voice greetings when someone approaches.  Theme fusion logic: Double section representative 'Reunion and returning home', the bus stop is the carrier for returning home;AI Empower the bus shelter with intelligent interaction, transforming static wooden models into interactive devices that can narrate festival culture.
2、 Innovation point
1. Structural innovation: Laser cutting modular assembly of basswood mortise and tenon joints, integrated cutting of curved louver ceilings, which can be assembled without the need for glue; Layered cavity design, independently divided into electronic component compartment, speaker compartment, and motor fan compartment, with wiring hidden in the gaps of the board, resulting in a neat appearance.
2. Functional innovation:
 AI Voice InteractionASR-PRO2.0 offline / Online voice recognition, Q&A on traditional cultural knowledge of Mid Autumn Festival and National Day, broadcasting holiday blessings, simulating bus arrival reminders;
Human body sensing trigger: Infrared sensing detects the approach of a person, automatically starts the cooling fan, and the relay controls the power supply;
Solar energy storage: The top solar panel is paired with a lithium battery charging module for daytime energy storage, achieving low-power self-sustaining power supply and adhering to the concept of green creation.
3. AI Integration method:AI Dual empowerment, early stage AI Auxiliary styling + Layout design; Physical installation AI Voice chip, realizing human-machine dialogue and combining virtual and real.
4. Cultural expression highlights: The location of the bus stop is chosen in a campus setting, symbolizing the reunion of students during the Mid Autumn Festival and National Day holidays by taking a bus home; Double Festival greetings and folk Q&A content closely follow the theme of Mid Autumn Festival moon viewing and national celebration, integrating festival stories into interactive voice.
Xiaohang Assistant
Drawing Cover - Xiaohang Assistant
CO2 RF tube
10W
0:17:16
process parameters
Design sketches, perform carving, prepare components, assemble
drawing ID: SUCAI-1645 2026-10-13 09:53
20Contribution points
Update time 2026-10-13 09:53
