Ancient style Xuanji Bell design project
Drawing video
Inheriting the shape of the previous generation gear clock, the number and relative position of gears have been re planned to achieve opposite rotation of the left and right sets of staggered gears. During rotation, the internal hollow patterns interlock with each other, forming a unique dynamic dizziness effect; At the same time, a clock hammer component is added to further enhance the mechanical rhythm of the device. The central disc is engraved with the directions of the Big Dipper at dusk throughout the four seasons, and the axis is fixed on the North Star, restoring the traditional way of timing stars in ancient times. The composition incorporates Chinese elements such as sundials, guzheng, auspicious dragons, and auspicious clouds, integrating the wisdom of ancient times, the elegance of literati string music, and traditional auspicious imagery. Gears rotate back and forth like Xuanji, replicating the meaning of time sequence changes, blending mechanical ingenuity with classical Chinese aesthetics, echoing the "Xuanji Yuheng" in the Book of Documents, which states, "Xuanji Yuheng, to unify the seven policies The distant artistic conception of timed observation. (The accessory material is the same as the previous one)
Xuanji Bell
Drawing Cover - Xuanji Bell
CO2 RF tube
10W
6:26:46
process parameters
none
The installation process is very simple, and everyone can explore it by themselves. If you encounter any problems during operation, please feel free to leave a message in the comment section for discussion and exchange. In addition, we look forward to friends who have successfully downloaded and created your work sharing their results in the comments section for everyone to enjoy together!
Related Recommendations
5 Contribution points
comment (1)
96780y7q
Oh, this can only be downloaded by buying coins
2026-8-1 14:11
drawing ID: SUCAI-1540 2026-9-6 20:41
0Contribution points
label
Update time 2026-9-6 20:41
