Carving light brings blessings, a new paper is born "- Year of the Horse pendant design project
Don't throw away the red envelope after opening it, let the laser give it a second life! This is not an ordinary Spring Festival decoration, it is a precise collision of technology and New Year's flavor. Through precise laser carving, the festive red envelope transforms into a visually stunning acrylic pendant. This not only demonstrates the technological advantages of laser technology in irregular cutting and multi material processing, but also provides innovative ideas for mass production in festival cultural and creative industries.
pony pendant
Drawing Cover - pony pendant
CO2 RF tube
0:2:33
process parameters
cutting 3mmacrylic Horizontal unidirectional 99 16 1
cutting Red envelope Horizontal unidirectional 15 45 1
Bill of Materials
3mmAcrylic, red envelope, glue
Processing equipment:Thunder Bolt Pro ,30W
design process
1Open itLaserMakerSoftware, click on the file, import the image
2Click on the contour extraction function in the upper right corner of the image to extract the contour of the image
3After extracting the contour, delete the original image, check the extracted contour, optimize the shape, and only need the outermost contour
4Modify the dimensions of the graphic
5Use circular tools to draw a circular cut for easy assembly of parts
6In order to have patterns on both sides, it is necessary to copy a graphic and then use a mirror image
7Copy again2A graphic, because it needs to be2The acrylic block needs to be pasted, so an offset tool is needed to offset it2mmKeep only the outer frame.
8Set processing parameters and pay attention to distinguishing cutting parameters for paper and acrylic.
processing
1After the device is successfully connected, send the drawings to the devices separately
2Put in the processing materials, please note that the red envelope needs to be opened
3Focus on materials
4Positioning of processed materials
5After ensuring that the settings are correct, you can start processing
Processing completed
1After processing, remove the finished product
2Tear off the protective film of the acrylic
3Assemble the materials
4Work completed
Related Recommendations
5 Contribution points
5 Creation Coin
drawing ID: SUCAI-1178 2026-4-14 08:58
0Contribution points
label
Update time 2026-4-14 08:58
