useUNO+Ultrasonic ranging module+Xiaoma has created a 'water cup cooling device'
The following photo shows the circuit we need to use
If we only look at the name and circuit, this work doesn't have much visual appeal
So I remembered the laser cutting machine+Adding a shell to this work with oak wood
The finished product looks like the photo below
In order to maintain a consistent style, the fan blades are also made of wooden boards
When there is a water cup in front of the device, the motor starts to rotate to cool down the cup
When the water cup is removed, the motor stops rotating
Below is the usageLaserMaker2.0Drawing made
