Christmas Decoration Painting design project
This Christmas wreath decoration painting cleverly combines traditional Christmas elements with modern designs. The white hollow pattern on the dark wood looks particularly beautiful, combining the refreshing elegance of winter with the warm atmosphere of Christmas.
Using laser customized products,Hanging on the wall inside the house can also add a festive atmosphere to the home.
christmasart
Drawing Cover - christmasart
30w
none
1:35:38
process parameters
cutting Basswood board - 80 30 1
It looks better to use three different colors of wood to match
For good texture, solid wood and segmented templates can be used+poplar+cherry wood
3The layers are all cut, and after cutting, they are glued together with white milk
If there are no wooden boards in multiple colors, then cutting and coloring the wooden boards can also be done.
Or use colored acrylic cutting for more colors.
Related Recommendations
5 Contribution points
10 Contribution points
2 Creation Coin
comment (1)
Purified water
111
2026-10-28 08:57
drawing ID: SUCAI-985 2025-12-19 16:28
50Contribution points
label
Update time 2025-12-19 16:28
