Laser cutting design diagram | Water tower design drawings
Water towers, commonly used for storing water in residential areas, are also an important component of water plant production processes. A towering structure used for water storage and distribution, used to maintain and regulate the water volume and pressure in the water supply network. It mainly consists of a water tank, a foundation, and a support tube or bracket connecting the two. In industrial and civil buildings, water towers are a common and special structure. Its construction requires special attention to detail and craftsmanship. If the construction quality is poor, it may cause permanent water leakage or even render it unusable.
well1
Drawing Cover - well1
0:17:44
drawing ID: SUCAI-950 2025-12-12 15:20
20Contribution points
  • classification
  • copyright
  • Business License
    Further information
Update time 2025-12-12 15:20
