Acrylic Snow Mountain Lamp design project
Project BackgroundToday, I would like to share with you a super cool snow mountain lantern
Hand in hand, I will take you to seal Mount Fuji on the desktop
Drawing Cover - Acrylic Snow Mountain Lamp
CO2 RF tube
55W
0:1:24
process parameters
cutting 5mmacrylic - 99 20 1
Step 1 Design concept
For this project, we only need a few pieces of acrylic and oneRGBLamp board is sufficient
Design four triangles as sides
A square serves as the base and is finally combined into a four sided pyramid
Step 2 Equipment List
5mmacrylic sheet
RGBlight panel
damping hinge*8
Step Three drawing
Design a four sided pyramid, a four sided triangle, and a square on the ground with the following dimensions
Step Four processed parts
Process the designed drawings, and the finished parts are shown in the following figure
Step 5 assembly
useUVThe printer gradually changes the blue and white color on acrylic
noneUVThe printer can also use colored frosted acrylic, and the effect is also good
Assemble the light panel and damping hinge
Step 6 Finished Product Display
drawing ID: SUCAI-802 2025-8-5 10:21
0Contribution points
Update time 2025-8-5 10:21
