bird's nest design drawings
1. Design concept: The design of this bird nest aims to provide a safe and comfortable habitat for birds, while integrating modern craftsmanship with natural ecology. Starting from the living habits of birds, we focus on practicality and aesthetics, hoping to attract birds to build nests and reproduce, and help improve the urban ecological environment.
2. Production process: Laser cutting technology is used to accurately cut wooden components. This technology can achieve millimeter level cutting accuracy, making the edges of various components in the bird's nest smooth, with precise dimensions, and tight seams at the joints, ensuring structural stability. The cutting process is efficient and does not cause excessive damage to the wood material, maximizing the preservation of the original characteristics of the wood.
3. Structural features: The overall shape of the bird nest is a classic house style, with a circular entrance design that conforms to the entry and exit habits of most birds. The size has been calculated to facilitate the entry and exit of common birds while also blocking natural enemies to a certain extent. The roof is equipped with hollow small windows, which not only ensure ventilation but also reduce the weight of bird nests and enhance visual aesthetics.
4. Material selection: Natural and environmentally friendly wood is selected, with a sturdy and durable texture, good corrosion resistance and waterproofing, and can adapt to the changing outdoor climate conditions. The natural texture and color of wood also allow bird nests to better blend into the natural environment.
bird's nest
Drawing Cover - bird's nest
0:6:14
comment (2)
wyjjjj
great
2025-12-8 09:25
Da Vinci
666Get down a stick mother
2026-5-29 18:22
bird's nest
drawing ID: SUCAI-776 2025-3-28 09:56
26
10Contribution points
Update time 2025-3-28 09:56
