Eiffel Tower design project
Eiffel Tower(French:La Tour EiffelEnglish:the Eiffel Tower)
[font=-apple-system, BlinkMacSystemFont, "]The Eiffel Tower is tall300Meter, antenna height24Meter, total height324Mi, the iron tower is composed of many scattered steel components - it looks like a pile of model components. Steel components have18038One, weighing10000Ton, drilled during construction700Ten thousand, using1.2Ten thousand metal parts, using rivets250Ten thousand. Except for the four legs which are made of reinforced concrete, the whole body is made of steel and shares wrought iron7300Ton.
[font=-apple-system, BlinkMacSystemFont, "]We use laser cutting machines for miscellaneous tasks+Wood can quickly make models of the Eiffel Tower.
Eiffel Tower
Drawing Cover - Eiffel Tower
0:19:56
comment (1)
3id2pnvt
Always showing 'loading' when downloading
2026-6-23 17:41
Eiffel Tower
drawing ID: SUCAI-424 2024-6-5 10:56
10Contribution points
Update time 2024-6-5 10:56
