Laser cutting design diagram | Laser cutting machine design project
Laser cutting machine focuses the laser emitted from the laser into a high-power density laser beam through an optical path system. The laser beam is irradiated onto the surface of the workpiece, causing it to reach its melting or boiling point, while high-pressure gas coaxial with the beam blows away the melted or vaporized metal.
laser cutting machine
Drawing Cover - laser cutting machine
0:13:56
comment (4)
WeChat users_44
Is there assembly teaching available
2025-10-16 14:24
smallQ
So exquisite
2025-12-9 16:19
ludjpaeg
pretty
2026-6-23 12:37
Always_5099
33
2026-3-26 21:22
drawing ID: SUCAI-379 2024-5-30 10:01
20Contribution points
Update time 2024-5-30 10:01
