Laser Cutting Design Drawing | Pterosaur design project
Pterosaur, also known as pterosaur(Pterosauria)It is an extinct reptile with a total of nearly100Multiple varieties. Although they lived in the same era as dinosaurs, pterosaurs were not dinosaurs. [2] The Greek word means "winged lizard" and is an evolutionary branch of flying reptiles. Survived from the Late Triassic to the end of the Cretaceous period, approximately2a hundred million1000Ten thousand years ago6500Ten thousand years ago. Pterosaurs were the first vertebrates to fly, and their wings were derived from the skin membrane located between the lateral sides of their bodies and the four phalanges of their wings. Early species had long and toothed jaws, as well as long tails; Newer species have significantly shortened tails and lack teeth. There is a significant difference in body size among pterosaurs, ranging from forest pterosaurs like birds to the largest flying creatures that have ever appeared on Earth, such as the Wind God Pterosaur and Hartzegopteryx, with wingspans exceeding12Mi, there are teeth10Centimeters long, with a huge pointed mouth.
pterosaur
Drawing Cover - pterosaur
0:5:38
drawing ID: SUCAI-273 2024-5-17 11:19
10Contribution points
Update time 2024-5-17 11:19
