Ballet piano is a piece made based on control board and expansion board.
Used seven button modules
Button module connection
Normal servo motor9gServo is sufficient
| 3mmBasswood board | - | - | - | 1 |
File shared through online storage: Piano
link: https://pan.baidu.com/s/1BVry7mfYoFRH4VnDeBnBwg?pwd=5wg9 extraction code: 5wg9
--From Baidu Netdisk Super Memberv3The Sharing
