This work is a set of laser cut wooden mini table and chair models, assembled using a splicing structure without the need for glue. The desktop and stool are intricately carved with mandala patterns, with rich layers of patterns and petal shaped contours on the edges, full of retro decorative beauty.
The table and chairs adopt a cross type support structure, using boards to insert cards into each other to form a stable bracket, cleverly utilizing mechanical structure to ensure overall stability, showcasing the structural charm of board splicing.
The work combines traditional decorative patterns with modern laser processing techniques, serving as both a craft assembly model and a desktop ornament.
26187749givev123v4ygf
