Wooden Swan Napkin Stand design project
This design features a wooden swan shaped napkin holder that combines functional storage and decorative charm. Suitable for desktop use, adding an elegant atmosphere to the dining environment. adopt4Millimeter wood laser cutting highlights the graceful form of swans with its simple contours.
Drawing Cover - Wooden Swan Napkin Stand
CO2 RF tube
10w
0:6:3
process parameters
cutting timber Horizontal unidirectional - - 1
Import files, laser cutting and finished product assembly
Translate into EnglishDXFFile ImportLaserMakerSoftware to align graphic dimensions; Adjust the cutting power and speed parameters according to the thickness of the board, preview the path without errors, and save the engineering file.
Place the wooden board on the laser workbench for positioning and start cutting. After cutting, remove the board, clean the burnt edges, and assemble it according to the mortise and tenon structure to obtain the swan napkin holder.
drawing ID: SUCAI-1539 2026-7-26 13:23
0Contribution points
Update time 2026-7-26 13:23
