1/90ttMotor adaptation
| - | - | - | - | 1 |
No step content available at the moment
Why can't I upload the attachment file?
DD
Hello, what format is your attachment in? I can help you provide feedback to the technical team.
回复 admin:lcpxordxfdrawing documents
回复 ties:The Third Empire, Guhongi WJQI didn't get it
回复 ties:Hello teacher, the comment section now supports uploading attachments. You can give it a try
Give a thumbs up to Teacher Bai
It took half a day to complete..... Looking forward to it, this year, various iterated tracked vehicles will start running across the country......
For the convenience of grinding together, the machining drawing of the rack has been modified
handsome
Track assembly drives people crazy..........Iterate a small version, reducing the workload of making tracks by half
ghjklghjk,l.
Come and learn! I would like to ask what kind of board the expert uses, what are the cutting parameters, and if there are any tips for edge treatment.
123
handsome
