Ruima Makes Yuanxiao (Filled round balls made of glutinous rice-flour for Lantern Festival) design project
This work takes the Yuanxiao (Filled round balls made of glutinous rice-flour for Lantern Festival) of the Year of the Horse as the core theme, and relies on laser precision cutting technology to create a double-layer stereo visual effect. The design integrates the auspicious animals in the Year of the Horse and the folk symbols of the Yuanxiao (Filled round balls made of glutinous rice-flour for Lantern Festival) Festival. The horses step on the auspicious clouds and the lanterns reflect the Yuanxiao (Filled round balls made of glutinous rice-flour for Lantern Festival) Festival, which not only shows the technological precision of laser processing, but also conveys the festival blessings of the new journey of horse leaping and Yuanxiao (Filled round balls made of glutinous rice-flour for Lantern Festival).
Drawing Cover - Ruima Makes Yuanxiao (Filled round balls made of glutinous rice-flour for Lantern Festival)
CO2 RF tube
30w
0:57:26
process parameters
cutting 3mmBasswood board Horizontal unidirectional 80 15 1
cutting cardstock Horizontal unidirectional 30 50 1
Bill of Materials
3mmLimeboard, red cardboard, glue
Processing equipment:Thunder Bolt Pro ,30W
design process
1Open itLaserMakerSoftware, click on the file, import the image
2Click on the contour extraction function in the upper right corner of the image to extract the contour of the image
3After extracting the contour, delete the original image, check the extracted contour, and optimize the graphic
4Additionally, copy another outer frame for cutting red paper
5Set processing parameters
processing
1After the device is successfully connected, send the drawing to the device
2Add processing materials
3Focus on materials
4Positioning of processed materials
5After ensuring that the settings are correct, you can start processing
Processing completed
1After processing, remove the finished product
2Stick the red paper and wooden board together with glue
3Work completed
Related Recommendations
10 Contribution points
5 Contribution points
comment (3)
delta
Great:100:
2026-5-18 20:49
zz0fmrrk
Awesome awesome
2026-4-23 11:03
delta
Great
2026-5-18 20:50
drawing ID: SUCAI-1163 2026-4-14 08:56
0Contribution points
label
Update time 2026-4-14 08:56
