Acrylic horsehead wall hanging design project
This laser processed acrylic horsehead wall hanging is compatible 2026 Creative decorative works for the Year of the Horse.
It uses laser cutting + Stacking process presentation: The acrylic sheet is precisely cut to outline the horse's head, and after multiple layers are stacked, a dynamic three-dimensional sense is revealed through light and shadow. The transparent material has a light and transparent texture, which not only retains the sharp lines of the horse, but also conforms to the minimalist aesthetic of modern space.
2026 Year is the Year of the Horse in the lunar calendar Carrying the cultural imagery of progress and freedom, this wall hanging piece can be used as a home decoration for the Year of the Horse / The theme decoration of the space is also adapted to daily display with a minimalist design, which is a light decoration work combining traditional zodiac symbols with modern laser technology.
Horsehead Wall Hanging3mmacrylic
Drawing Cover - Horsehead Wall Hanging3mmacrylic
CO2 RF tube
50W
0:21:27
process parameters
cutting 3mmacrylic Horizontal unidirectional 99 18 1
design process
1、LaserBlockSearch for "horsehead wall hanging" in the laser community and need to refer to this original drawing for creationLaserMakerOpen the drawing in the software
2Due to the thickness of the original image4mmmodify to2.7mm
3Reset the processing power,3mmAcrylic, weak blowing, speed18, Power99, corner power99
4In order to save materials, the drawings were rearranged
4、 Processing process
1After the device is successfully connected, send the drawing to the device
2Add processing materials
3Focus on materials
4Positioning of processed materials
2After ensuring that the settings are correct, you can start processing
finished product assembly
1After processing, remove the processed parts
2Tear off the outer layer of acrylic film
3Assemble in order according to the sequence
4Finished product assembly completed
Related Recommendations
10 Creation Coin
5 Contribution points
drawing ID: SUCAI-1069 2026-4-14 08:57
0Contribution points
label
Update time 2026-4-14 08:57
