Pulse laser welding of stainless steel sheet - LaserBlockLaser Forum Pulse laser welding of stainless steel sheet - LaserBlockLaser Forum
Activity Technical exchange LaserMakerdownload mobile phoneAPP 多语言切换 English
release
design project
Present a complete idea, including design specifications, drawing files, parameter settings, etc
design drawings
Display drawing files
post
Technical exchange area, where any questions or doubts can be discussed
Laser light sources are relatively concentrated and have accurate directional positioning during laser movement, so lasers have always been considered an ideal heat source in welding processes. Due to the effect of laser heat source, the weld seam obtained by laser welding has a small melting width, deep melting depth, and small deformation of the welded part. These characteristics make laser welding of great practical value. Nowadays, laser welding can be seen in the processing of equipment such as space shuttles, automotive skins, and machine parts. This course introduces the basic principles of laser welding, laser welding equipment and processes, as well as pulse laser welding of stainless steel sheets.
Learning prices 920 Creation Coin | original price:¥ 1360.00
learning frequency177 time
popularity2128
Study duration permanently valid Calculate the validity period from the date of purchase
The laser light source is relatively concentrated and the direction is accurately positioned during the movement of the laser, so the laser is always
Considered as an ideal heat source during the welding process. Due to the effect of laser heat source, the welding obtained by laser welding
The narrow seam width, deep penetration, and minimal deformation of the welded parts make laser welding practical
The value is relatively high, and laser welding can be seen in the processing of equipment such as space shuttles, car skins, and machine parts nowadays. This course introduces the basic principles of laser welding, laser welding equipment and processes, as well as pulse laser welding of stainless steel sheets.
No evaluation content available at the moment
There are currently no supporting materials available for the course
